OK, here is the story.
Proggie has been working 100% for ages now, but the other week I downloaded an avi (xvid) file. Tried to convert to DVD and program froze at 4.1%. Ive since done a complete re-install of windows thinking that may be the problem but no, its not.
Every time I run it, it freezes at different points (latest was 27%). When i go into task manager, the CPU useage for this program and the fffmpg assosiated with it is 00. System idel is 99/98.
Ive uninstalled it/reinstalled it, and still the same.
I'm now gonna attempt to edit the registry to the same values as my other pcs with this great program. Will post the results soon.
Ive also checked the file and that is not the problem.
ANY help would be greatful. - TIA
== Always happy to assist ==
If you have had success with the same file on other PCs have you looked at the sticky: https://forum.videohelp.com/viewtopic.php?t=265207
It works 100% on all other PCs. Ive just got all the dust outa the heatsink and installed another case fan (2 in total now). Im running a program called speedfan which tells me the temp inside the case. 2 points are at 62 deg c, so I think that i may need to install new heatsink & fan/get some of that thermal paste one of the threads talked about. Let you know the outcome in a couple of days.
== Always happy to assist == -
OK. Just installed brand new heat sink and fan as well as an additional fan on the case. also got shut of all the dust (god there was loads of it!). But still the program hangs.
Any ideas anyone please?
TIA== Always happy to assist == -
Gna try another proggie to convert AVI-DVD. Watch this space!
Just finishd with the other proggie (ConvertXtoDVD by VSO) and that works 100%. Any ideas?
TIA ppl.== Always happy to assist ==
MEGui FREEZES!!
By mark63534 in forum Newbie / General discussionsReplies: 0Last Post: 23rd May 2010, 21:43 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 01:35 -
Pressing Capture Button Freezes Program
By Mengsk in forum Capturing and VCRReplies: 13Last Post: 5th Jun 2008, 17:45 -
how to filter away freezes ?
By cyflyer in forum MediaReplies: 3Last Post: 24th Feb 2008, 17:51
