    Apr 2006
    Hi there.
    I was looking around to find the solution for my problem, but I couldn't.
    I got DVD Boxet. There are 4 season with 6 DVD-s. Every DVD has 4 episodes.
    Can somebody instruct me or help how to convert every single episode, from DVD to AVI?
    I'm intrested to convert episode by episode. Like one single episode to a single AVI file and NOT to make a single AVI file from 4 episodes.
    Any way I can do this with your help?
    Thanks in advance
  2. Hi--
    Decrypt using DVD Decrypter in IFO Mode (up at the top, Mode->IFO. It'll show you first the longest episode, but look around in the various VTS's for the various episodes. Decrypt each to a different folder. Then I would suggest using AutoGK to encode each episode to XviD. It has a batch feature so that after you set each of them up, it'll encode them one after the other.
    Nov 2002
    And please remove the title of the stuff you're doing, as you're leaning dangerously close of piracy and may be modded.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Why ? It could have been a birthday present or something.
    As for the OP, https://forum.videohelp.com/viewtopic.php?p=1373527#1373527 might assist and make things a little easier. I'd almost guarantee that each disc will follow a similar sturcture ie PGCs 1-4 will be each episode. The method mentioned above will allow you to rip all 4 eps at once into seperate VOB files, which you can then feed into AutoGK and batch them as manono suggested. Should make the ripping process almost a point-and-one-click operation.
    If in doubt, Google it.
    Apr 2006
    guys,
    thank you very much for you assistance.
    kind regards
