Is there product that can send video in a PC to a USB2 port and convert it to S-video or composite video for displaying on a TV?
No you need a video card with a video out port. You can get one really cheap on an auction site if you're not going to use it for high powered gaming. Than you can use a svideo cable and a ysplitter to get the line out from your soundcard to the tv/vcr.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I am still looking for a solution that would allow me to view video on a TV from an HP s7320n.
https://forum.videohelp.com/viewtopic.php?t=298481
https://forum.videohelp.com/viewtopic.php?t=298292 -
I'm at work, but PM me on this. I might have an inexpensive alternative that you'll probably find with just as good as or better quality than what you're looking at. The video cards you were looking at are primarily for running video from a source into your PC, not Really the other way around. though the AIW cards do support a nice video out function via composite or S/Video. I have a box I haven't used in a while and can't remember the name, but it worked great for displaying video from my PC onto a 36" television clearly, and the monitor at the same time. It didn't need the monitor connected, but the port is on it and available for use.
Doramius,
Please tell me more when you have time. Note the other thread. Thanks.
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 22:48 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 22:57 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 23:46 -
Video Recording with EasyCap USB2.0 audio/video recorder
By eliqush in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2009, 15:54 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19
