Hi,
I want to rip episodes off episodic discs without losing any quality. I used to be on XP and managed to do it, but burning it became a problem and any DVDs I burnt with epsiodes on always had skipping, even though the DVD images on my computer worked fine.
I'm now on a Mac and can use XP if I have to on my laptop. I think the problem last time was in burning movie files to a disc, so is there a way I can rip the episodes out directly in full quality (don't mind removing say the foreign languages/subs) and burn the episodes as data files, so they won't pay in a dvd player but I can play them on my computer? I've tried this using Handbrake on my Mac and it won't do it.
I don't mind how big the episodes they are but I'm a freak and want them all to be in perfect quality, even if that means only one or two episodes being burnt onto each DVD-R.
Thanks.
I think your original problem was poor quality blanks. Either that, or a poor job of authoring the DVD.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
The authoring worked perfectly I think, as I have the video_TS and audio_TS folders on my computer and they work perfectly
. I'd bought a spindle of 100 DVD-R Imation discs, were they the problem then?
Would it be possible to extract each episode singly instead of getting them in video_TS and audio_TS format? -
https://forum.videohelp.com/viewtopic.php?p=1373527#1373527 might assist.
Shows you how to queue ripping in IFO mode in DVDDecrypter.If in doubt, Google it. -
well, imitation disks is ur problem, there are 10 times as many bad disks out there as there are good
Episodic DVD ripping problem
By grandmastashi in forum DVD RippingReplies: 5Last Post: 10th Jan 2011, 09:43 -
What program do you use for ripping up your dvd/blu-ray discs?
By johns0 in forum PollsReplies: 19Last Post: 3rd Sep 2010, 17:31 -
Ripping DL Discs and Im confused...
By frieday in forum Authoring (DVD)Replies: 10Last Post: 8th Oct 2009, 00:18 -
Ripping Region 2 discs on Mac pro
By jabbo5150 in forum MacReplies: 6Last Post: 22nd Feb 2009, 11:46
