Hey i just started capturing video from my motorola comcast dvr box and heard that there is some audio video sync issues to worry about when capturing this video.
Is there a program to check if my captured video has A/V sync problems other than watching it from start to finish?
Also Wat is a simple program to correct av sync problems
There is not going to be a program to watch and listen to your video for you. How would something like that work?
As to correcting the sync issue, have you bothered to read the stickies?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
If your problem is with AVI files try AVIMux GUI:
https://www.videohelp.com/tools?tool=AVIMux_GUI
Also, read this post:
https://forum.videohelp.com/viewtopic.php?p=1338598#1338598 -
No i didnt look in the sticky's. are there sopme good ons about a/v sync issues? ill take a look.....
does this avi mux work with mpeg files? -
[quote="mikej3131"]...does this avi mux work with mpeg files?[/qu
Sorry to say, no it doesn't. It just works with AVI's.
audio out of sync? please check
By cesarin in forum EditingReplies: 4Last Post: 22nd Dec 2011, 09:41 -
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 08:10 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17
