It seems when in IFO mode by chapter DVD Decrypter is not ripping all files. Example:
VTS_01
PGC 1
PGC 2
PGC 3
PGC 4
It only ripped the chapters in PGC2. Do I have to manually select the other PGCs or can I set Decrypter to automatically do this?
Any help would be grealty appreciated.
Yes, you have to manually select each pgc that you want to rip. By default, IFO mode will automatically select the largest pgc, which is usually the main movie set.
As MistaED said re: selecting the largest PGC.
One way around this is to use DVDDecrypter in commandline mode via a batch file. See https://forum.videohelp.com/viewtopic.php?p=1373527#1373527 for more info.If in doubt, Google it.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
how to generate missing ifo file from dvd
By deejay.2001 in forum Authoring (DVD)Replies: 14Last Post: 2nd Jun 2008, 10:53 -
missing ifo-files
By scio_fantasio in forum MacReplies: 5Last Post: 12th Dec 2007, 23:04 -
DVD Decrypter IFO I
By drstew in forum DVD RippingReplies: 6Last Post: 2nd Dec 2007, 23:42
