Hi guys!
Haven’t posted on here for a while – posted on the capturing forum a lot!
I have a question with Adobe Encore 2.0.
I just bought it, and I took one virtual tutorial and have read two text tutorials, however, I’m having an ongoing problem that I just can’t kick!!
Every time I try to insert a Timeline (Ctrl-T) I keep getting the following error message:
Here's the error message I keep getting:
Could not import file FILE-NAME.avi.
Video files for this project must have a resolution of 720x480, 720x486, or 704c480.
At this point, all I want to do is start creating your most basic menu template for a DVD.
I’ve searched google ‘till the sun went down, but no luck!!!
Any help would be appreciated, I just don’t know what I’m doing wrong!
Thanks for reading.
Jenny![]()
That sounds like you have a non-dvd format resolution. In order for it to be dvd mode you need to have it formated to dvd specs. Its telling you your file is not ready as it is. Programs like tmpgenc can reencode it to your proper spec.
Read the what is dvd section https://www.videohelp.com/dvd for the proper resolutions of your area (ntsc usa/canada/mexico - japan? pal is basically everyone else). Once you get it into your proper dvd resolution you should be able to proceed as normal. (don't forget the audio must be 48khz for dvd).
Try gspot or avicodec on the file to see what the current resolution of the video is then you'll know what you need to convert it from.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hi guys!
Thanks for the responses yoda313 and tarzan1990!
I'm still not figuring this problem out yet!!
And, I realized that I posted this in the wrong forum, so I reposted this in another one - sorry about the inconvenience :P
I reposted this at:
https://forum.videohelp.com/viewtopic.php?t=297230
Anyway, if the moderator wants to delete this, go right ahead!
Thanks!
Jenny
Simpler to keep this one going and have a mod move it.
When you insert a new timeline, do you do this by adding an AVI file to the project ? (I don't use Encore, so I am not familiar with the workflow)
If so, what are the details of the source (Codec, resolution, framerate) ?Read my blog here.
end of file--Adobe Encore
By koberulz in forum Authoring (DVD)Replies: 19Last Post: 18th Oct 2016, 20:21 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Encore
By mobie29 in forum Authoring (Blu-ray)Replies: 33Last Post: 6th Jan 2011, 01:09 -
Adobe Encore CS4: How to reduce output file size?
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 8th May 2010, 12:19 -
Adobe Premiere Pro CS4 Cannot Import .mp4 File
By spike32 in forum EditingReplies: 5Last Post: 19th Jan 2010, 08:15
