I just finished encoding an XviD .avi with DIKO. This is the first movie I have encoded since updating to 2.23 form 2.12. I have always authored my .mpv and .ac3 files to DVD externally from DIKO with either TMPG DVD Author Pro or TSUNAMI-MPEG DVD AUTHOR PRO and had perfect results every time (I author externally because sometimes the .ac3 or .mp3 files included in .avi files have a delay and DIKO does not seem to detect it when extracting resulting in out of sync audio). This time though I receive a similar error message in both programs when trying to author. They read as follows:
TMPG DVD Author Pro:
The Video GOP is too long.
TSUNAMI-MPEG DVD AUTHOR PRO:
38 Fields is too long for a video GOP. The DVD-Video standard requires that the GOP maximum length is as below.
NTSC: 36 fields (18 frames)
The DIKO Log Reads as follows:
11:58:39 - DIKO Free 2.23
11:58:39 - -----------------------------------------------------
11:58:39 - *************************
11:58:39 - * Getting movie info... *
11:58:39 - Processing Movie 0:C:\Temp\Video1.avi+
11:58:39 - Script Template: .\scripts\avi\DivXHighQuality.avs
11:58:39 -
11:58:39 - Progressive Width: 656 Height 352 A.R.: 1.863636 Framerate: 23.976000 Dest. Framerate: 23.976000 Frames: 193424
11:58:39 - Audio type: 8192 (AC3), channels: 5 Frequency: 48000 Hz Bitrate 448 kbps
11:58:39 - Audio for this movie won't need to be reencoded! Yes!
11:58:39 - Calculated Audio size: 441.185978 Mb
11:58:39 - ***************************
11:58:39 - * Processing Subtitles... *
11:58:40 - *******************
11:58:40 - * Calculations... *
11:58:40 - Total audio space: 441.185978 Mb
11:58:40 - Media Size: 4482 Mb
11:58:40 - Mux Overhead: 140 Mb
11:58:40 - Remaining space for video: 3900.814022 Mb
11:58:40 - Total length: 134.456679 minutes
11:58:40 - Desired Sample Size: 40.674154 Mb QFactor Adjust used: 1.000000
11:58:40 - Average Bitrate: 3961.061254
11:58:40 - **********************************
11:58:40 - * Initiating prediction phase... *
11:58:40 - * Encoding Video... *
11:58:41 - Re-Creating movies scripts without sampler for Full Encode
11:58:41 - Encoding... Please Wait this can take many hours depending on your processor.
11:58:41 - Processing Movie 0:C:\Temp\Video1.avi+
11:58:41 - C:\Program Files\Video Tools\CCE\EclCCE.exe -ecl "C:\Program Files\Video Tools\DIKO\Temp\movies.ecl" -encode -exit -hideshutdown
15:51:29 - Enabling pulldown flag... Command-line:
15:51:29 - DGPULLDOWN\DGPulldown.exe -i "C:\Program Files\Video Tools\DIKO\Temp\movie0.mpv" -c -s -1
15:51:29 -
16:28:14 - Pulldown returned an error flag.
16:28:14 - Pulldown Sucessfull. Renaming original file and the pulled-down one.
16:28:34 - ********************
16:28:34 - * Audio extraction *
16:28:34 - Extracting audio from movie with VirtualDubMod...
16:32:00 - ---------------------------------------
16:32:00 - ********************************
16:32:00 - * Initiating audio encoding... *
16:32:00 - Processing Movie 0:C:\Temp\Video1.avi+
16:32:00 - Fix errors and remove WAV header using AC3Fix from file 1. Command-line:
16:32:00 - dvdauthor\ac3fix.exe "C:\Program Files\Video Tools\DIKO\Temp\extract0a.wav" "C:\Program Files\Video Tools\DIKO\Temp\movie0a.ac3"
16:33:54 - C:\Program Files\Video Tools\DIKO\Temp\movie0a.ac3
16:33:54 -
16:33:55 - Renaming movie 0 files to its final name...
16:33:55 - 0 - DIKO finished processing!
16:33:55 - DIKO Finished the conversion. If everything
went fine, your files should be in the working folder.
The strange thing is that I never had this problem with DIKO 2.12. The only difference I can detect between the two versions is in the configuration in the Mode setting. 2.23 is BDVD instead of KDVD in 2.12. I would appreciate any help with my problem. Thanks
Thanks for the reply... If anyone is familiar with DIKO I would like to know what setting is responsible for the adjustment of the GOP and how can I alter that to create compliant DVD video? BTW... I know that the encoding process is the problem and not this particular .avi because I have tested it with several different XviD .avi files with the same result.
You will find that is a fairly common problem when authoring with TDA. Here is some discussion of it:
https://forum.videohelp.com/viewtopic.php?p=1303959#1303959
You can find a lot more by doing a forum search for 'GOP is too long'. I ignore it most of the time, but it will create a non-standard DVD. They usually work fine. But you would likely have to re-encode to change it. I'm not really familiar with DIKO. -
Thanks for such a quick reply redwudz...
Just one more question... If anyone is familiar with eclCCE I am using it with DIKO as my encoder. I was wondering if the settings in this program can be altered independently of DIKO to correct GOP length. If not I guess DIKO is the problem. Also, if I am forced to look elsewhere for "one click" conversion software what other program will...
#1- Maintain 5.1 channel .ac3 audio
#2 Allow for external authoring of my DVD from .mpv (or similar MPEG Elementary Video) and .ac3 files
#3- Will use eclCCE or CCE as the encoder?
Thanks to all who take their time to help me out!
Avi files "Not Support Video" on dvd player?
By aelfheah in forum DVD RippingReplies: 11Last Post: 12th Sep 2011, 12:18 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Need help converting DVD video using MeGUI's "clever anamorphic"
By mjensen in forum DVD RippingReplies: 0Last Post: 5th May 2008, 09:41 -
How long is your "Live Free Die Hard" movie on DVD R1 ?
By NiteLite in forum Newbie / General discussionsReplies: 4Last Post: 1st Dec 2007, 16:27
