i got a fitness avi i want to convert to dvd, with only 3 chapter for each seperate session
is it best to split the avi into 4 then encode each one
i want 1 chapter to start with the intro and then another 3 start at each of the 3 parts of the routines
whats the best prog (free if poss) that will enable me to do this, without much to technical stuff
Results 1 to 11 of 11
That is a hard question to answer. What WinAVI produces as output seems to depend more on which way the wild goats are facing on the eastern slopes of the himalayas at sunset than any ability the program itself has.
WinAVI is held in very low regard by many people here, and rightly so in my view. By all means, try it, and if it works, more luck to you.Read my blog here.
Read my blog here.
didnt work
i converted the avi, but when i tried to "add video" it didnt want to know
Best method for splitting up an .avi into various chapters and burning
By aple in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 21:24 -
Unable to create chapters while converting from AVI to DVD using DVDAuthor.
By sumit_pankaj in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2009, 02:40 -
From DV avi to PS3 with chapters?
By vihenrik in forum Newbie / General discussionsReplies: 1Last Post: 10th Oct 2008, 13:56 -
Makeing DVD from avi. with Custom Chapters
By Eternal7331 in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2008, 21:31 -
AVI+DVD+Chapters = ???
By eMacNobie in forum MacReplies: 9Last Post: 13th May 2007, 19:07
