i have a movie with audio codec MEDIA_SUBTYPE_DTS (0x2001) Dolby Laboratories, Inc
i try to convert the audio to mp3 layer with Virtaeldub but always the same message
No audio decompressor could be found to decompress the source audio format. (source format tag : 2001)
he can't open the move i try and i install all codecs i can found in the net with the same result
plz help
thanks
check guide, threads etc on converting dts to mp3. If you want to use V/Dub, might have better luck converting to wav first. You'll also probably find it helpful reading about muxing/demuxing.
First, you need to install a software player that supports DTS playback, such as some versions of PowerDVD. Then I would use virtualdub only to demux the audio track so you have a standolne DTS file. Then I would look at hypercube transcoder for converting the DTS to something else.
Read my blog here.
nah thank u but i try nothing work i just wonna to convert the avi coz i can't play it in my dvd player before i convert ac3 and others with V/D and so easy but this one good he drive me crazy and i have only that file of a rare movie , plz is there is some soft or way , i try to make .wav file and it work then i try to conver it to mp3 or real wav but same damn thing no filter
Read this thread and see how you go
https://forum.videohelp.com/viewtopic.php?t=294461Read my blog here.
how do i remove DTS from AVI, convert audio then remux..?
By snadge in forum Video ConversionReplies: 6Last Post: 3rd Dec 2009, 07:58 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 02:49 -
AVI with DTS wont play - can I convert?
By snadge in forum AudioReplies: 4Last Post: 29th Jul 2009, 10:41 -
Convert divx avi with dts to ac3
By mk15 in forum AudioReplies: 3Last Post: 23rd Jun 2009, 04:46 -
How to convert AVI with DTS audio to DVD
By Jean in forum Video ConversionReplies: 6Last Post: 24th Aug 2007, 02:25
