Hi,
I ripped one DVD using DVD Decrypter and then I tried to make DVD Unauthor in order to make a MPEG of the main movie
I used a tool from DVDAuthor (sourceforge), but the resulting MPEG plays backwards and there is missing frames....very strange
How can I convert/unauthor a DVD to a MPEG-2 file with the main movie ?
thanks
Results 1 to 11 of 11
ask the creator of vob2mpg, https://forum.videohelp.com/profile.php?mode=viewprofile&u=60062
Rip as one large vob instead of separate ones with Dvd Decrypter.ffmpeg.exe -i VTS_03_1.VOB -i VTS_03_2.VOB -i VTS_03_3.VOB -f mpeg2video -sameq -ar
Why do you need ffmpeg when vob2mpg does the job for you?
Anyway: you need to concat the vobset before you use ffmpeg. So eitheror useRip as one large vob instead of separate ones with Dvd Decrypter.Then use ffmpeg but not the params you tried or the whole thing will be reencoded and thus you will loose quality. UseCode:copy /b VTS_03_1.VOB + VTS_03_2.VOB + VTS_03_3.VOB VTS_03.mpg
as this will not touch the video or audio and will just iron out any timing issues brought about by joining the files in the first place.Code:ffmpeg -i VTS_03.mpg -target dvd -vcodec copy -acodec copy output.mpg
Thank you very much, ChrissyBoy and you all
Thats was the trick : rip as one large vob
I managed to make it work with FFMPEG
it converts this large MPEG-2 file to AVI, very quickly
but I have this problem
https://forum.videohelp.com/viewtopic.php?t=293695
