Closed Thread
  1. Hi all
    I have a footage 1 hour long which was setup as 25fps 1.067 pal 48000hz, using premiere pro 1.5. I did this as i reside in the UK. When I go into FILE>EXPORT>BURN TO DVD, i see in the bottom left hand corner that the file is a whopping 4.1GB and the DVD itself is the normal 4.38GB.
    So here's my question, How do I downsize the file say to 2GB so i can fit 2hrs worth on the DVD, But the last thing i want to do is to lose quality either in sound or what you actually see?
    Please can you explain in lamen terms as I am new to this premiere pro 1.5. I also have adobe encore 1.5. Can this software help at all?
    Kind Regards Josel
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator vitualis
  2. Do not post the same topic in more than one forum.
    https://forum.videohelp.com/viewtopic.php?t=293222
    Regards.
    Michael Tam
    w: Morsels of Evidence
