I have made a multi with some 30min avi files but the S2D files that are created are out of sync?
I have used the to fit option.
Any Ideas?
Results 1 to 14 of 14
How do you discribe the off sync? Is it out form the beginning? Are the files in the same VTS and the off sync occurs after the first asset?
There are 9 avi's that are all on seperate vts's and i used the fit option which meant they were encoded in half dvd mode.
All the avi's are in sync but the created S2D files start off a little out of sync and by the end they are lots ot ouf sync. -
Can you try: https://forum.videohelp.com/viewtopic.php?p=1338598#1338598
to see if that solves your issue?
(just try on one avi first)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I tried that and the resulting S2D file is still way out of sync.
CAn you ftp me one?
Spot on... Did you update the registry first? What about if you just try it on the file you sent me?
i did update it assuming it worked ok is there a way i can check it updated the registry?
are there any special settings i need to use in the avi convert prog thing? -
You don't need to use the avimux program.
Make sure you have the following registry:
HKEY_CURRENT_USER\Software\Badger I.T.\SVCD2DVD 2.0\FFMPEGASYNC
with a value of 200SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ok sorry i thought i had to put through avimux again will try again this eve
Ok just try the single file first to confirm..... BTW that certainly brought back memories!
the registery entries are correct but is still out of sync do i need to reboot the computer for the registry entries to work?
s2d won't work after running Register Mechanic 9.0
By delgee65 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2011, 15:41 -
S2D have its own settings when using imgburn ?
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 20th Aug 2009, 17:36 -
Can S2D do this?
By drbenjamin in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th Nov 2007, 18:25 -
How to save converted *s2d.mpg in another folder???
By junkfood in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Sep 2007, 10:01 -
Nero Burner in new version of s2d version5
By couzican in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Jul 2007, 18:50
