I'm having quality problems with DV camcorder footage transferred into Canopus Lets Edit 2. During panning scenes there is quite noticeable horizontal striping, almost as if the fields are out of phase.
I am transferring from Pana NV-GS3 using quality firewire cable direct to PC's port (P4 3.2 with VIA controller). Have also tried passing through my ADVC-100 into different firewire port, with same problem.
Windows Moviemaker and Pinnacle studio 7 or 9 do not show same problem, so I guess rules out hardware. Have tried to change 'capture' settings in Lets Edit but only seem to be able change file type for import i.e AVI type 2 or ref AVI. Video is PAL, PC is HP MediaCentre M7xxx
Anybody had similar probs or any ideas on how to fix ?
Hi ripcurl,
Welcome to the forums.
Try transferring from cam to PC via firewire, but using WinDV - it's free and is regularly recommended. I swear by it...
Here's a recent post of mine on one way of configuring WinDV:
https://forum.videohelp.com/viewtopic.php?p=1387878#1387878
https://forum.videohelp.com/viewtopic.php?p=1255226#1255226
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
At a guess the striping with be interlacing, and is normal. Look it up in the glossary. Some software deinterlaces on playback, some doesn't. If the software doesn't you will see the stripes. If you destination is DVD, then this is not a bad thing, and you should just continue on regardless, comfortable in the fact that once you have transfered it to DVD, it will look fine on your TV.
Read my blog here.
As suggested I used Lets Edit to transfer and then produce an Mpeg2 from a DV clip, cheerfully ignoring the interlacing problem in the preview window. I used TMPGEnc DVD author to produce a DVD, played back on TV - and everything was fine, no quality problems at all.
I also used WinDV and Pinnacle to transfer the clip, encoding to MPEG2 in Procoder. Both of these worked equally as well, resulting DVD was also fine.
So now I'm spoilt for choice all three routes produce the same result!
Thanks for the advice guys. -
Carpe diem.
Is there any software that lets you edit 1920 and do green screen or roto
By Onceler2 in forum EditingReplies: 7Last Post: 2nd Oct 2011, 05:08 -
FLV Input Plugin for Virtualdub lets you save as AVI with no quality loss?
By gumbygum in forum Video ConversionReplies: 7Last Post: 1st Aug 2010, 15:08 -
Can I transfer CCD V5000 Hi8 Analog Video to digital on my Macbook to edit?
By thebird in forum EditingReplies: 2Last Post: 25th Apr 2009, 11:06 -
How can I transfer CCD V5000 Hi8 Analog Video to digital/MAC to edit?
By thebird in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2009, 05:36 -
what freeware editor lets you edit left and right portions of your wav
By Onceler2 in forum AudioReplies: 15Last Post: 11th Jan 2009, 09:46
