  1. A little background on my issue:
    I created a dvd using DivxtoDvd and it didn't create any click-able menu so that I can select which movie to watch form it. (It has 1 long movie, and then another movie split into 2 separate files.)
    When I try to watch it with WinDVD it just starts right at the first move, and I assume it will just play all 3 files straight through since I can't actually select anything. I would like to know if it is possible to simply create a basic clickable menu, nothing fancy with animation or sounds or anything, and then insert it into the already created ts_video stuff? I'd especially like to be able to do so without a full 9 hour recode and/or possible drop in video quality from the recode.
    I'm a newb to this and don't really know what software to do this with if possible. I tried to import the ts_video folder using Tmpgenc DVD Author but it just popped up a dialog box with a bunch of odd characters, an error of some sort, and then didn't import anything. I'm downloading Nero 7 now to see if I can do it in there.
    Any help greatly appreciated!
