Simply question:
After dragging an AVI to the timeline, there is sound but no video, it happens with all of my AVI's
Anyone? lol, thanks![]()
I had two things Driving me nuts....Not being able to import Xvid/Divx into Vegas, and having to Change the 4CC to be able to.
What started was my Computer/Vegas would not import Xvid or Divx,But My wifes computer/Veags would."Without Changing the header "4CC". WHY?? This is what bothered me.!!
I found out what the probelm was. First You need to install The Divx codec "of course". I installed the pro Trial version.Still works to decode Video when the trial is up,Just cant Encode.
The main thing is to UNISTALL "XviD video codec" this is where the conflict is, with this Codec.
You may have problems with the Audio,But just De-Mux it then import it into Vegas.
Hope this Info Helps somebody...... -
Thank mate, I have just installed DivX 6.0, my AVI's are now visableOriginally Posted by canadateck
Cheers
AVI in Vegas 9
By thedunker in forum Video ConversionReplies: 3Last Post: 18th Apr 2011, 16:30 -
VLC and Vegas export DV AVI
By Abas-Avara in forum Software PlayingReplies: 0Last Post: 28th Feb 2010, 06:34 -
sony vegas and avi
By wingfan in forum EditingReplies: 4Last Post: 5th Nov 2007, 21:15 -
Vegas problem
By Tackleberry in forum EditingReplies: 12Last Post: 3rd Nov 2007, 12:28 -
AVI files in SONY VEGAS
By thompskm in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2007, 06:44
