As some of you may have heard, there's a nasty windows expl0it
floating around that Microsoft has yet to patch. Currently, there is
an unofficial patch out that SANS is endorcing, and you might want
to look in to it (is uninstalliable if problems occur)
For more info on the WMF (can be any file extention now not just the WMF ext) exploit - http://antivirus.about.com/b/a/231816.htm
Windows WMF Metafile Vulnerability HotFix (Unofficial) - http://antivirus.about.com/gi/dynamic/offsite.htm?site=http://www.hexblog.com/2005/12/...mf%5Fvuln.html
Opps! Maybe a move to 'Computers' ? Sorry about that Mods!
Sabro
www.sabronet.com - It's all you need...to know
In Outlook:
1.Do not open attachments unless you know it's safe.
2.In Tools->Options go to Security and enable "Block images and other...."
3.In Read enable "Read all messages in plain text".
4.In View->Layout disable the preview pane. -
Moving you.
/Mats -
Actually, just unregistering the dll doesn't cure the problem...again a search produced no results as to why I originally posted....but its good someone beat me to the punch with the current avail fix...
Sabrowww.sabronet.com - It's all you need...to know -
http://www.hexblog.com/security/files/wmffix_hexblog14.exe
Download this patch from GRC.com and apply it. It is suppose to work much better than just unregistering the DLL. Install and reboot and you are protected until MS patches it themselves. Then you can just remove this patch via Add/Remove programs. -
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
Panasonic ES35V. Ive joined the masses. NO READ ERR Any new info on a fix??
By DAVE440 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 21st Feb 2012, 19:10 -
A required codec is missing-MP4, to fix please read www.copytrans.net
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2011, 12:07 -
SRT exploit?
By drgt in forum Newbie / General discussionsReplies: 10Last Post: 7th Oct 2010, 12:10 -
Windows XP zero-day Exploit
By Poppa_Meth in forum ComputerReplies: 6Last Post: 16th Jun 2010, 15:46 -
the "fix" for the current i.e.6,7,8 exploit is now available at m
By aedipuss in forum ComputerReplies: 4Last Post: 21st Jan 2010, 20:05
