Results 1 to 20 of 20
    Oct 2005
    U.S.A
    i have tried to make a back-up of this movie.i use icopydvds2 and the updated version of dvd43.i can not get it to make the copy.at 20 mins remaining it freezes up.i have cleaned the disc so i know it is not that.also everything else copies fine.
    any help would be great.thanks
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    USA
    It may have one of the newer forms of copy protection. You can try DVDFab Decrypter as yoda313 mentions and that should rip the DVD to your hard drive. You can process it from there with your choice of programs. I use DVD shrink at that point. Some of the newest DVDs may take more than that to backup. If so, someone here has likely done it and may be able to give you some tips.
  4. Originally Posted by redwudz
    I can confirm that.
    Within an hour of unwrapping Fantastic Four, i downloaded the latest DVDFabDecrypter, and had no trouble at all using DVDShrink to fit to single layer DVD.
  5. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Update software
    What We Do In Life, Echoes In Eternity....
    Dec 2005
    Just used shrink by itself without any problem
  7. I used DVDshrink without any problems.
  8. I also used dvd decrypter and dvd shrink and worked like a charm.
    Life is like a pothole, you just have to learn to get around it.
  9. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I used DVD DECRYPTER as well then DVD REBUILDER PRO and no problems at all.
  10. shrink by itself
  11. Member Super Warrior's Avatar
    Newer forms of copy protection? Hahahahahahaha!!!!
    It ripped perfectly for me with zero problems and i use Smartripper.An older,outdated program that stopped getting updates about 3 years ago.
  12. I used Anydvd and DVD shrink. It worked fine.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  13. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    What he said
  14. Member Weapon's Avatar
    Nov 2004
    Portland, OR
    It ripped fine for me, I used old fasioned DVD DECRYPTER and DVD Shrink.
    Mabey your copy has the new "Pizza Sauce Protection".
  15. Banned
    Jun 2004
    LMAO!!!!! i remember that thread/grease
  16. Banned
    Jun 2004
    Originally Posted by Supreme2k
    Actually i was thinking of this one 8)
    unable to decrypt a movie with DVD Decrypter/DVD shrink
  17. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Yeah, but jim's always ripping off my best lines.
  18. Banned
    Jun 2004
    Yeah, seem's like i caught him once or twice
    But i was talking about the guy trying forever to rip a disc and the reason he finally realised he was having problems was the "greasy fingerprints" on it, the post above his
  19. Greetings Supreme2k's Avatar
    Feb 2003
    Yup. Truth is always stranger than fiction (or comedy).
