Using Smartripper, just point it to the files, then click the Stream processing tab. Highlight the video stream and choose "Demux to extra file" and you're all set.
You can check here for further detail:
http://www.doom9.org/index.html?/sr.html[/img] -
Exactly. Just make sure to un-check all other streams, except video.
Of course, make sure you enable stream processing. -
Vobedit will also do this, with smartripper don't forget to press the 'save selection' button once you have selected the stream you want, I always forget to do this
Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm -
See the eject and reload buttons next to the Smartripper logo in the picture above? To the right of the Reload button, there is a folder icon. Click on that, then navigate to the folder where your vob files are.
How to view/extract EIA-608 text from m2v stream?
By jairovital in forum SubtitleReplies: 15Last Post: 14th Apr 2012, 08:47 -
Extract .m2v and .mp2 files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2010, 12:42 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Extracting VOBs To M2V gives me alot of problems.
By Discov3r3d in forum DVD RippingReplies: 5Last Post: 18th Aug 2009, 15:41 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
