Hi,
i am looking for a tool able to convert some ts files to mp4.
These ts files contain a H264 (mpeg4 avc) video stream and a AAC sound track
Only the ts container shall be converted to mp4, not the video nor audio stream which shall stay untouched.
I tried many tools but all of them encode the video and audio stream.
avidemux should be able to do the job since there is an option "copy" for both video and audio but unfortunately it always crashs.
joel
Results 1 to 16 of 16
Maybe you can try demux the audio and video tracks with tsmuxer and remux with mymp4boxgui or yamb to a mp4.
Or
ffmpeg -i video.ts -acodec copy -vcodec copy new.mp4
But you migh get sync issues..ts h264 conversions/remuxing isn't that simple. -
Hi
Use FFmpeg like this:
Code:ffmpeg -i foo.ts -c copy foo.mp4
Information here ---> https://forum.videohelp.com/threads/343895-Pass-Thru-presets-for-WinFF
I have found that handbrakecli and the latest FFMPEG can reliably read MTS & TS files, and encode from that. I can also repack audio and video into an MKV with codec copy & FFMPEG if so desired. The problem I had prior was OLDER versions of both.
Cheers,
Andrew -
Try vlc. Media>convert/save... Have used it to convert to and from certain containers; original audio and video streams remain untouched.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
I want (even my player plays ts file nicely - but for others) convert a ts stream file into mp4 file w/o reencoding it. It was downloaded from there:
http://www.ceskatelevize.cz/porady/10408111009-cesky-zurnal/214562262600003-matrix-ab/
By using YTD 1.52: http://www.pepak.net/ytd/youtube-downloader/
The resulting file is 2G big (2 078 509 200 bytes) and I would like to create a mp4 file from it, so I can be replayed easily by others (uploading to YouTube seems to work).
Now at first, I tried the FFMpeg ways mentioned there:
ffmpeg -i x.ts -c copy x.mp4
ffmpeg -i x.ts -acodec copy -vcodec copy x.mp4
Both failed with this:
Code:encoder : Lavf57.2.100 Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 1280x720 [SAR 1: 1 DAR 16:9], q=2-31, 25 fps, 25 tbr, 90k tbn, 90k tbc Stream #0:1(ces): Audio: aac ([64][0][0][0] / 0x0040), 44100 Hz, stereo, 118 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help [mp4 @ 03c82a00] Malformed AAC bitstream detected: use the audio bitstream filter 'aac_adtstoasc' to fix it ('-bsf:a aac_adtstoasc' option with ffmpeg) av_interleaved_write_frame(): Operation not permitted [mp4 @ 03c82a00] Malformed AAC bitstream detected: use the audio bitstream filter 'aac_adtstoasc' to fix it ('-bsf:a aac_adtstoasc' option with ffmpeg) frame= 3 fps=0.0 q=-1.0 Lsize= 170kB time=00:00:00.25 bitrate=5467.6kbits /s video:170kB audio:4kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Conversion failed!
TS muxing (is not that the original?!)
M2TS muxing (not mp4, useless for me)
Blue-ray ISO (not mp4, useless)
Blue-ray folder (even more useless)
AVCHD folder (now come on...)
Demux (uhm...)
...and that it is. How can I get a mp4 from this is beyond me... but maybe I do something wrong?
Next step was Virtual Dub external encoder. I never tried it before, but looks like that it is kinda easy to do, when using someone vdprof files and external encoders. Used guides there:
https://encodingtalk.com/threads/virtualdub-save-direct-to-mp4-fraps-to-youtube-with-e...encoders.2446/
http://forum.doom9.org/showthread.php?t=171141
...and got it to work, but it says that I cannot use direct stream copy, witch was what I tried from the beginning:
Reencoding does work, tough.
Suggestions welcome."I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config -
TorBru -
And what happens if you do as ffmpeg suggests?
Code:ffmpeg -i x.ts -c:a copy -c:v copy -bsf:a aac_adtstoasc x.mp4
Code:Input #0, mpegts, from 'x.ts': Duration: 01:13:15.40, start: 2.040000, bitrate: 3783 kb/s Program 1 Stream #0:0[0x3e9]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 12 80x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x3ea](ces): Audio: aac (LC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 118 kb/s [mp4 @ 03e95aa0] Codec for stream 0 does not use global headers but container fo rmat requires global headers [mp4 @ 03e95aa0] Codec for stream 1 does not use global headers but container fo rmat requires global headers Output #0, mp4, to 'x.mp4': Metadata: encoder : Lavf57.2.100 Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 1280x720 [SAR 1: 1 DAR 16:9], q=2-31, 25 fps, 25 tbr, 90k tbn, 90k tbc Stream #0:1(ces): Audio: aac ([64][0][0][0] / 0x0040), 44100 Hz, stereo, 118 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy)
_Al_ - interesting possibility. Maybe next time...?Thank you!
The Video to video converter is better and more accurate software than the above mentioned examples.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
Tool that gives more info about .mp4 than GSpot
By Wam7 in forum Newbie / General discussionsReplies: 15Last Post: 7th Nov 2019, 04:51 -
What tool(s) for MP4 to MKV conversion with no reencoding?
By zdvd in forum Video ConversionReplies: 35Last Post: 17th Dec 2016, 07:38 -
mp4 tool
By cdv in forum Newbie / General discussionsReplies: 7Last Post: 20th May 2010, 20:18 -
best tool from video/audio TS to mp4 h264
By nodollas in forum Video ConversionReplies: 1Last Post: 31st Jan 2010, 06:55
