  1. Member bat999's Avatar
    Feb 2008
    Hi
    "Pass Thru" presets for WinFF.
    These can be used...
    1. To extract the audio track from files.
    2. To re-mux files in different containers.
    Latest version of WinFF for Windows and Linux is available from here ---> http://winff.org/html_new/
    To import the presets...
    Unzip the file in the attachment below.
    Filename is "pass_thru_presets.wff".
    (There is also a package named "OLD_pass_thru_presets.wff")
    (This is for any Linux users who have old versions of FFmpeg installed)
    Then...
    WinFF > Edit > Presets > Import
    Then SAVE.
    The presets are:-
    Pass Thru avi
    Pass Thru flv
    Pass Thru flv(Audio)
    Pass Thru m4a
    Pass Thru m4v
    Pass Thru mka
    Pass Thru mkv
    Pass Thru mov
    Pass Thru mp3
    Pass Thru mp4
    Pass Thru mp4(Audio)
    Pass Thru ogg
    Pass Thru wma
    More information about creating WinFF presets is here ---> http://code.google.com/p/winff/wiki/HowToMakePresets
    Additional information added...
    When using "PassThru" presets with WinFF, some files give errors:-
    "Application provided invalid, non monotonically increasing dts to muxer in stream..."
    A workaround is to use VLC instead of WinFF.
    Use latest version of VLC from here ---> http://www.videolan.org/
    Run it from the command line ---> http://wiki.videolan.org/Terminal
    Use commands like this:-
    vlc foo.flv --sout="#std{access=file,mux=avi,dst='foo.avi'}" vlc://quit
    and this:-
    vlc foo.flv --sout="#std{access=file,mux=mp4,dst='foo.mov'}" vlc://quit
    and this:-
    vlc foo.flv --sout="#std{access=file,mux=mp4,dst='foo.mp4'}" vlc://quit
    Also, "PassThru avi" and "PassThru mov" and "PassThru mp4" presets can be added to VLC.
    (Media > Convert/Save... "Keep original video track" and "Keep original audio track")
    Like this:-
    Last edited by bat999; 13th Mar 2012 at 22:51. Reason: VLC workaround for "non monotonically increasing dts..."
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Cool. Thank You.
  3. How can I use the pass thru on my flv files, but change the apect ratio from 4:3 to 16:9?
    I don't think you can add any aspect ratio in a flv. Add it in the player or make a mp4 or mkv with 16:9 display aspect ratio.
    If you want to resize the video you must reconvert.
    Jun 2014
    South Africa
    YAY!!!!
    This is exactly what I was looking for
    Jun 2014
    South Africa
    YAY!!!!
  7. thanks very much for this, I have questions later.
    Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
