VOB2MPG was working fine in XP. But when I upgraded to Windows 7 and reinstall, it will not register. The message is "There is an error registering the program. Please inform the author." I did via registration email, but cannot get any reply. Has anybody tried it on Windows 7?
There has been success on Windows 7:
https://forum.videohelp.com/topic368745.htmlDwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Thank you, Dwight, for pointing out the thread. However the particular thread was all on svcd2dvd. There was no success story on VOB2MPG which is the problem I have with on-line registraton. After following the advice and setting the file property of compatibilty to XP during the install, I still could not get a valid on-line registration. I would like to hear from the developer or someone who has actually installed VOB2MPG in Windows 7 and sucessfully registered. Thanks.
Finally success on Windows 7 32bit. This is what I did. 1) change property of setup application to Win XP SP2 and Privilege Level to "Run as an administrator". 2) set Compatibility Property of VOB2MPG PRO Setup to "Previous version of Windows" 3) install it in the recommended subdirectory outside of.. /Program Files/, ie., (c:/VOB2MPG PRO/). Voila! Online-registration worked! Back to being happy customer.
I hoped you would take those points away from that thread. I apologize for not elaborating further as I was short on time when I replied.
Dwight
- Herm Albright
Hi, I had the problem, too.
Do you run a x64 Windows 7 ?
I'm doing so.
So, to solve the problem you have to install some components from the .net runtime library. To do this, take a look in "Uninstall Software" click on activate / deactivate Windows components
There you will find "Microsoft .NET Framework 3.5.1" . Expand it and you will see 2 more options. Check both of them and click "OK"
After installing this 2 components Start it with Admin Rights and compatibility of Win XP SP2.
That ist what worked for me.
Looks like the x64 is not installing all neccesary components ti install the application.
Hope I could help -
Another problem on W7 is that it will lock up after a couple of successful runs with the following error below. It will run ok again upon re-execution. Just annoying.
ERROR MESSAGE COPIED FROM THE PROGRAM ERROR POP-UP BELOW:
Version: VOB2MPG PRO
Build: 3.0.0040
Type: System.Runtime.InteropServices.COMException
Source: DirectShowLib-2005
Message: The parameter is incorrect.
InnerException:
StackTrace: at DirectShowLib.DsError.ThrowExceptionForHR(Int32 hr)
at VOB2MPG_PRO.DVDPlayerCtl.ResizeVideoWindow()
at VOB2MPG_PRO.DVDPlayerCtl.DVDPlayerCtl_Resize(Objec t sender, EventArgs e)
at System.Windows.Forms.Control.OnResize(EventArgs e)
at System.Windows.Forms.UserControl.OnResize(EventArg s e)
at System.Windows.Forms.Control.OnSizeChanged(EventAr gs e)
at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
at System.Windows.Forms.Control.UpdateBounds()
at System.Windows.Forms.Control.WmWindowPosChanged(Me ssage& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at VOB2MPG_PRO.DVDPlayerCtl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) -
If your having problems getting the program to work with vista, or windows 7, you could look for an xp emulator so you can keep using programs that work on xp with your new operating system. Hope this helps
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 04:07 -
MeGUI problems since using windows 7 - PLEASE HELP!!
By qwertym in forum DVD RippingReplies: 4Last Post: 28th Mar 2010, 20:54 -
Still having driver problems with windows 7
By intheory in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2010, 18:18 -
VLC problems in Windows Vista
By 1234567 in forum ComputerReplies: 4Last Post: 8th Oct 2008, 16:45 -
DV & Windows Movie Maker Problems
By DavidA in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 19th Jun 2008, 16:40
