Because the old LG broke down, I had to buy a new LG, the RH387 (H).
Unfortunately, this item was not sold region-free, as my other LG's were.
Hacking for most LG's (7 times 0 on the remote) did not work either.
I have a large collection of import DvD's, so any hint is welcome!
Results 1 to 18 of 18
Thread: How to hack the LG RH387
According to this post: http://forums.hardwarezone.com.sg/sh....php?t=1916831
The unit requires a new firmware.Google is your Friend
here is how. good luck.
http://www.videohelp.com/dvdhacks/lg-rh387/9184
External hard drive works!
I bought a 1 terabyte external hard drive (it was SATA, so I couldn't put it into the RH387, which is IDE), re-formatted it as fat32, and loaded a bunch of movies on it. Once I plugged the usb line into the RH387 and selected USB from the home menu, it took two or three minutes for it to recognize the drive, but it eventually came up on the screen and shows and plays all the divx movies I put on there fine.
One more mark in favor of the LG.
I successfully did it to my LG RH387(h) a few minutes ago.
Follow the following steps wiith your RC:
MAKE THE DVD RECORDER REGION FREE:
A. press "Setup" on the remote control;
B. go onto padlock icon without selecting it;
C. press 0 button seven times;
D. a message will appear confirming that "your unit is now region-free"
make%20the%20dvd%20recorder%20region%20free.doc
I followed your instructions andOriginally Posted by wkong
1) no confirming message "your unit is now region-free"
2) anyway - it works
3) power off my rh387h
4) power on
5) i got a message "invalid region"
6) i followed your procedure again (many times), but no success
what is going wrong?
thx for help
I own an LG RH-387 DVD recorder and I have tried every hack mentioned here without success. When I tried to get into the LG site http://hk.lge.com/support/support_lgeservice.jsp "Product Support" in order to download the .iso file I get a compile error message and I cannot access the "Device Drive" page. All other attempts with the padlock and the 0's were with no success. Can anybody help?
I had the same problem but i found the correct file structure for the CD here http://www.multi-region.net/tevion_md_81335. Burn the CD_CODEFREE.zip contents to a CD.Make sure to finalise! Play it on your RH387 and you can set region=0 for zonefree.
The RH387.zip contains the RH387.ISO image that worked for me. Unit was bought Jan 2011
Same CD (iso image) worked on an LG DVX642H.Last edited by mnenz; 5th Feb 2012 at 02:30.
Wow....yet another thread full of first-time posters posting complete nonsense and rubbish in order to get their jollies somehow. Where do these freaks come from?
hech54: Get well soon!
That attachment worked, thanks a lot mnenz!
Had some problems with the initial instruction: http://forum.videohelp.com/threads/3...51#post2059951
Good, then maybe someone can help this person (if he's still waiting):
http://forum.videohelp.com/threads/3...=1#post2056331
I still remember how I could feel his panic in his words even through the text.Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
Even though it's completely off topic, I'd still like to comment - what would be interesting to many members is if you can reverse this process, in other words, by migrating files from the LG to the external hard drive.
You can bet bids will go up for it worldwide if so since none AFAIK can do that.
Nevertheless, LG makes solid decoders in their machines such as BD playing non-compliant BD, playing weird MPEG-4 files, MKVs, and recognizing appropriate PAR flags in AVIs, etc.Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
You are amazing! Super thanks!
I have tried many many MANY MANY suggestions but they all didnt work
This one worked like a charm!!!!
Thanks!!!!!!!!!!!!
ok people, my RH387H remote does not have any numbers on it so where do we go from here?
as I am in N.Z. it appears us kiwis get different stuff to you guys,all my remote has is the usual opperation buttons without the numbers,and LG have changed their site in the last few days,so can not acsess technical pages.I got the image up on the screen but obviously could not change to code free/0 - which brings me to this.thought i would go outside the square and alter the setting by opening the file on my pc and then put the cd back in the player.problem is I can not open the file on my pc.not reconised.
- the challenge to everyone is .........can anyone help?
Last edited by LGtony; 8th Jan 2012 at 17:59. Reason: just a little background info
LGtony,
On my remote for the RH387 the numeric pad is hidden under a sliding lid (lower half of the remote)..
mnenz
hi MNENZ,
well wouldn't you know i used a knife and hey presto there are the numbers.
the guy in the shop did not know either?
thanks........
un-hack a hack?
By hnw in forum DVD & Blu-ray PlayersReplies: 9Last Post: 9th Jan 2011, 10:30 -
LG RH387 compatibility with other players
By Pouib in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Oct 2008, 15:40 -
LG RH387-M Missing Weekly function for Timer Record?
By EmperiumXX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Jun 2008, 15:07 -
Hack help
By broleh in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:52 -
Need a hack
By kwaller in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th Jun 2007, 21:52
