Results 1 to 12 of 12
  1. Member lordhutt's Avatar
    Jun 2004
    Like the subject says....
    What do you think the best one out there is ....ignoring price.
    Looking for the one with the best features and options.
    Thanks.
    Apr 2004
    Miskatonic U
    there is no best, only what works best for you.
    for me, it is Vegas. it gives mo complete control over every aspect. it is a video editor, not a slideshow program.
    Read my blog here.
  3. Member isogonic's Avatar
    Jan 2003
    @localhost
    ive used proshow gold and uleads picture show, both very easy to use. pro show had more features. both have trial versions.
    Apr 2006
    Brazil
    I have used
    1. Pinnacle studio9
    2. Nero 6
    3. UleadVideoStudio 8
  5. Member dipstick's Avatar
    Jan 2005
    Dark side of the Moon
    I too believe the best Slideshow app is a good Video Editor. My preferance is Premiere, but you can get excellent slideshows using Wax2, wich happens to be free.
    I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
    Jan 2006
    Australia
    deleted
    Mar 2005
    Paddock Wood, Kent UK
    Hi
    I enjoy using 3D-Album, see http://www.3d-album.com/
    Paul W. H
    Mar 2006
    I use ProGold but I do so primarily because of the panning and scanniing capability. In my opinion a slideshow of timed pictures and some music is boring compared to one in which pictures are panned.
    A freeware app that has the panning feature is SSMM (Slide Show Movie Maker).
  9. Member GeorgeW's Avatar
    Feb 2005
    I often combine several apps to procude one longer slideshow (i.e. one song/slideshow will be done with product-x, another with product-y, etc...)
    These are some of my favorites because the save time by letting the software generate the transitions and music (but sometimes you need to use an editor to make certain customizations that the "automatic" programs cannot do):
    -MemoriesOnTV (codejam.com)
    -Muvee AutoProducer (muvee.com)
    -ProShow Gold (photodex.com)
    -CD & DVD PictureShow (ulead.com)
    -VideoStudio 10 Plus (from Ulead -- adds video editing to the mix, and also has an auto-music generation tool)
    Regards,
    George
  10. I used either Memory on TV or Screenblast or sometime both with TMPGEnc Author.
    Croatia
    Haven't tried many, but DVDSanta was very easy to use and produced all I needed for a slide show with cool transitions and background music.
  12. Member lordhutt's Avatar
    Jun 2004
    Thanks for all of the suggestions, everyone.
