i have movie which is bin/cue CD1 and bin/cue CD2 how can i joion them so it becomes one and then burn it to DVD
It is in VCD or SVCD
thank you very much
I usually extract them with a program like ISOBuster to MPEG, then add them to a program like ConvertXToDVD and burn to DVD. That's an easy way. ConvertXToDVD has a freeware version available lower on the page.
If they are SVCD, a program like SVCD2DVD may give better quality. Best quality would be using the individual tools for the conversion. The guides to the left would assist you in that. <<<<<< -
If they are VCD, then the video is already DVD compliant and you want to make sure that whatever tool you use, it doesn't re-encode it. Only the audio needs to be upsampled to 48khz.
Buy My Books
how to join 2 video_TS
By hilario in forum EditingReplies: 2Last Post: 6th Oct 2009, 17:33 -
How can i join wav?
By GangstaRap in forum AudioReplies: 1Last Post: 8th Jan 2008, 07:05 -
Cant join 2 AVI together!
By GangstaRap in forum EditingReplies: 2Last Post: 25th Dec 2007, 19:41 -
Cannot join two DVDs
By vertical in forum Newbie / General discussionsReplies: 9Last Post: 7th Sep 2007, 01:23 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 11:06
