Hi All,
I have been trying to create a weblink the manual tells me to go to www.webdvd.org for more info but as we all know this no longer exists. So my question is has anyone successfuly added a welink in Maestro and if so is there some guide or something out there to help me along?
Thanks[/quote]
Yes I have, and No the only guide I have seen is what's in the manual.
Basically, you just 1. set your preferences to allow weblinks, 2. make the corresponding fillin box in the TARGET dialog/tab for your button a URL (which can be a web address {http://www.blah.blah.blah.com} or file {file://mydocument.txt} or other common url-compatible script.
You really should thoroughly read the manual though, if you want to get the most out of Maestro.
Scott -
yes I have done all this but on compiling I get the message "button 4 has no target" it looks to me as though I have done everything correctly but obviously I haven't.
I'll check at work tomorrow with the manual to refresh my memory and then get back to you.
Scott -
To review, Check these things:
1. In Program preferences | WebDVD tab:
"Enable URL Entry for WebDVD" should be checked
2. In Project settings | General tab:
"Embed Project Text data" should be check, with appropriate language
3. If doing "Chapter Point" link, make sure you actually have a specific chapter point for the particular link. Add link text in "Marker URL" box.
4. For menu link, In Menu dialog | Buttons tab:
Put link in "URL" textbox
5. Also try title giving Menu button "Target" of itself. Obviously don't make it an auto-activating button or you will loop forever.
6. In URL link, use "http://www.dvdrhelp.com" (or whatever's appropriate). Use the full syntax and don't leave out the http part.
7. If doing file that resides on the DVD itself, use syntax of "dvd:......". While web urls use the "/", dvd urls should use the "\".
8. Test, test, test--with an RW disc. Try a number of different players.
HTH,
Scott -
In review:
1.WebDVD I did enable
2.I also did the embedded project data (as per the manual)
3.Yes Itried this
4.yes I definately did this
i even tried linking the button to a chapter URL and no luck I also did the menu target back to itself. I did use the full syntax line for the URL.
I did just have a thought though, I have only been testing it after compiling and using the built in dvd player. I have noticed that this DVD player does not always eflect the finshed "burnt" product so that will be my next test.
Thanks for all your advice Cornucopia i will let you know how I go.
Crusty -
Which "built-in" player are you talking about? The Ravisent/QI player, or the Syzygy, or something else like WinDVD/PowerDVD or WindowsMediaPlayer?
Some of those DO support Web-enabled DVD and some DON'T (obviously the syzygy does).
Maybe if you did a microDVD title (<10MB) that I could ftp to, I could check and see what's going on. I have successfully done a small number of these titles--some website, some document, so I know it can work correctly.
Scott -
Ok will do that and when I am ready I will post you the FTP site.
Thanks Again.
Link to stats
By stiltman in forum FeedbackReplies: 5Last Post: 19th Feb 2010, 17:12 -
use image as a link
By akakiami in forum Authoring (DVD)Replies: 3Last Post: 15th Oct 2008, 17:34 -
link together
By linkinparkfrk123 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 19:16 -
D-Link can't do it
By sue1951 in forum ComputerReplies: 4Last Post: 14th Aug 2007, 10:27 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 05:51
