is anyone 1 having this problem I cant seem to get this program to work . I am using windows XP
NEED HELP PLEASE
Results 1 to 10 of 10
Hi,
I'm having mixed results with DVD Shrink - the first DVD I tried was fine, can't remember what it was now, but since then I was also able use DVD Shrink with The Sixth Sense which worked perfectly using the re-authoring feature.
The problem I have is with Spiderman and now I have discovered the same problem with the UK release of Lord of the Rings (Original version, not the extended one).
I basically get the same cyclic redundancy error with both discs. Just for the record, I have been unable to use any of the other programs I have with Spiderman, I have yet to try using another program with Lord of the Rings.
Any ideas.... anyone???
Kyorin -
I'm having the same exact problem. Please somebody out there give a solutions. please, please, please!! and if you had a similar problem that you think my help please advise!!!
I have ripped a DVD to my HD and was trying to shrink it but got an Idle error or something when it was remaking the VOB files. Anyone had that before?
I started using DVDshrink 2 days ago. When it works it is a work of art. But I have had 2 errors.
Independence Day: Prior to my use with DVDshrink I tried several methods involving DVD2AVI, smartripper, and TMPedit. At best I was able to get mismatched audio with the video. DVDshrink basically closed down and would not go further than the main page. I also tried decrpting to a HD and reading into DVDshrink; same prob.
Star Wars Attack Of the Clones: After editing, etc it went through all the encoding but crashed on remapping. I tried it twice.
I have actual error messages at home but I wondering if this program is like others, where some DVD just don't work.
If anyone has any solutions...
PS When this does work. SWEEEET! -
I've noticed something that may turn out to be important with the cyclic redundancy problem - it would seem that I only have this problem when ripping discs that are Region 2. I haven't had any problems on any Region 1 discs so far!!!
I'm going to try using my DVD burner to rip one of the affected discs tonight, I'll get back to you with the results.
Kyorin
UPDATE:
Its not gonna happen with my Sony burner used as a reader - It takes waaaaaaaay too long to rip using my Sony DRU-500AX, I will have a normal Sony 16x reader next week hopefully... I think I can wait till then to see if it resolves this problem.
Kyorin -
I have the same problem w/ DVD shrink.. I think its because the discs are scratched/dirty. Any ideas?
Yeah the problem I believe is caused by scratched disc. I recommend you clean the hell out the disc, wipe it real good and try it again. It's really hit or miss at this point.
Yep! That did it. Windex and a paper towel, along w/ a CD cleaning cloth, did the trick perfectly.
I'm glad it did. Since i've been cleaning my disc prior to ripping I have not had any problems. So for everyone reading. THE ERROR MEANS...CLEAN YOUR DISK!! : ENJOY
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 01:32 -
What is "cyclical redundancy" in DVD Shrink?
By jyeh74 in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 08:51 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 21:35 -
VideoStudio 9 / DVD Shrink error: invalid data contained in file
By JediPM in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 16:20 -
data redundancy?
By beer31 in forum ComputerReplies: 5Last Post: 23rd Aug 2007, 00:32
