Hi All,
I have a new puter.. ASUS P4PE, P4 2.4, 1GB DDR, 80GB WD.. and an ASUS V9280.
My question is around the video card and video capture. When I capture from my VCR into the card, I get a slight ghosting on the video. It is especially noticeable when there is text on the screen... and when there is alot of "white" in the shot also. It also will distort the image slightly in "bright" scenes.. e.g. if the is a vertical line, it will look kinda wonky.
Previously I had an ASUS v3800 Ultra and My video capture was rock solid and very clean. I saw none of these problems on the old card, and I was using the same cables, VCR etc.
My VCR only has "Yellow, Red, White" in/out connectors (unsure of the correct term) and I use the yellow out connector from the VCR to connect to the ASUS-Supplied break-out box.
I might be a bit anal about it.. but I have a problem with the vid capture on my new, expensive card not being as good as the old one! :P
Oh, also I pulled the case out from under the desk.. straightened out the video cables etc.. but it made no difference. Perhaps a high quality video cable might help? Gold plated etc? *sigh*
Has anyone else experienced this? Either on the same card, or another one? Any suggestions on how to overcome it? Or should I just get over it? :P
I look forward to your replies.
Thrashin.......![]()
Results 1 to 1 of 1
Old video card ghosting - any way to fix it?
By Ai Haibara in forum ComputerReplies: 7Last Post: 15th Feb 2011, 15:49 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 11:40 -
ASUS TV Tuner problem with Video in & audio adaptor
By Zpazt in forum Capturing and VCRReplies: 0Last Post: 16th Jul 2008, 15:30 -
Ghosting on PAL VHS CApture
By tumaz in forum RestorationReplies: 30Last Post: 4th Oct 2007, 16:59 -
anamorphic & ghosting/blur problem on Premiere Pro 2.0
By marcos316 in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2007, 00:14
