I ripped 3 mpgs from a .bin file.
The Joined them using Mpgtx Version 1.3 - (Missing Mpg Tools Concarente wouldnt work, wheni tried to do 3 files). I also use Missing mpgs join tool.
I ended up with a joined file which came out to be around 2.04 GB.
I then muxed them using Missing Mpg Tools. And got to files which were .m2v and .mp2.
Next I muxed them together, using HillmanMinx Software, and also used Sizzle. But when they were both done, the file size was only 800.8 MB.
I am trying to make them into DVD format, so that they will play on most dvd players. HillmanMinx makes a nice .img file as well as Video TS and audio TS Folders.
I also did each file seperatly, and had a video TS, and Audio TS for each, but I did not know how to name the files correctly, because each folder had a bunch of files which were called the same.
PLEASE HELP ME
Meatball10
Results 1 to 1 of 1
