  1. Is there an easier or faster way to cut an 1GB MPG file into two????
  2. Hey,
    Use TMPGEnc in the wizard window 3/5 go to source range and set the end frame to the middle and then open it again a set the start frame from the middle (see that they match the frame num. is written)
