Hello! I use Pinnacle studio 8 deluxe to capture old vhs through my sony camcorder to my harddrive. I then use TMPGEnc to to compress the video. I was wondering after I compress the video, which is the best program to burn the video to dvd? Thank you very much for your help.
Standard nero can't author dvds.
Ulead Moviefactory and Workshop(more settings) are easy to use and not that expensive and demos are also available. If you want have full controll of the dvd authoring try the beta of dvdlab.
