  1. Can somebody please help me.....Is there anyway for me to burn an .ogg file to VCD? or at least extract the movie file with the language & subs that I want?? Any & All help would be greatly appreciated....thanks!
  2. I use CDex to convert .ogg audio to .mp2,I don't know about .ogg video.
    www.cdex.n3.net
  3. yeah i dont think it does video...thanks anyway homie
  4. Member DJRumpy's Avatar
    Dallas, Texas
    You can use decompress.exe
    It's part of AVI2VCD, and AVI2MPEG. You can find it here:
    http://www.mnsi.net/~jschlic1/
    Unfortunately, it will convert any multichannel to simple stereo, but it will handle OGG audio input. It basically takes your avi, and creates a new copy, with the audio in uncompressed format. This can then be fed into your editor of choice.
    Impossible to see the future is. The Dark Side clouds everything...
  5. thanks.....k but now i got the video & audio i want perfectly....but how do i get the subtitles??? They aren't permant subs cause i can switch them to several languages, so how can i either get the subtitles to be permanent or extract the subtitles & add them wth another program? sorry if i am confusing anyone
  6. Member DJRumpy's Avatar
    Dallas, Texas
    I can't help you there. I've never had any interest in subtitles. Someone should be able to help you out though. You did follow the links to doom9 though didn't you? They should lead to some guides describing what your looking for.
