Hi everyone! I have a 2 GB m2v video file ripped from a DVD that has 15 seconds of dead air and blank video right in the middle of the movie(prolly from when the laserdisc flipped over). I've had no luck finding an editor that will recognize (by default, most look for mpeg, mpg, or mpv files) ripped m2v video files, allow you to edit them, and then re-export them as m2v. All the editors I've seen and used such as tmpGenc, M2-Edit, MpegVCR, SonicDVD, Adobe Premiere 6.5, etc, don't look for, and prolly don't support m2v files.
When I do import them, in something like Premiere 6.5, they play at 2x the play speed and export as such or with a shuttering framerate.
Does anyone know of an mpeg2 editor that accepts m2v files, understands them, allows you to cut and merge, and will export them too? Thanks!
-Chaz
Thread: Real m2v file editor out there?
Rename it to mpv. The extension should not matter. If it doesn't work it is something else that is wrong(maybe it isnt a mpeg video only file...).
Its definitely a video only file. I used DVD2AVI and TmpGEnc to demux it from a DVD. I'll try renaming it and try again. I'll keep you posted on how it comes out. Thanks!
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
MPEG Layer 2 video file, is it an editor friendly file type?
By ferran275 in forum Video ConversionReplies: 18Last Post: 16th Apr 2010, 23:41 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
PSP video file editor
By efiste2 in forum Portable VideoReplies: 1Last Post: 27th Jun 2007, 18:07
