i've got a DivX rip of a movie, and i want to make it a DVD, so I came here and followed the DivX to DVD guide. to let u know what i did, i'll tell ya (gonna be a long post ):
1st. i got the DivX (.avi) and opened Virtual Dub and extracted the audio following the guide here on this site 2nd. I opened TMPGEnc (Version 2.59.47.155) and opened the wizard and selected DVD NTSC and followed the steps and started encoding from there.
now i got this *.m2v and a *.wav file. but in the wizard all it implied that i should of renamed it to *.mpg which i did but still came out w/ those 2 file types... what do can i do? is there a way so next time i encode a DivX file that i dont have worry about anything after (so that i can just end up with a *.mpg file)? Thanx for listening, and I hope yall can help me out here!
It seems as if you left something out. When you use the wizard it should have asked you for a video file to encode and an audio file. You would load the avi file in the video section and the wav file in the audio section. The resulting film should have both audio and video and should have an mpg extension. It looks as though you only encoded the video and not the audio.
I don't do DivX but if you used the wizard in TMPGEncPlus and ended up with a .m2v and .wav file in step 5 of 5 you had to have the separate output file checked. To produce only a .mpg file uncheck the ES System separate output option in step 5 of wizard and end up with only a .mpg with both video and audio in one file.
(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Doggiedaddy,
It seems as if MystaMax didn't encode the audio at all. From what he says in his post he started with a wav file and ended up with a wav file. By the way, do you think you and I are related? We seem to have the same last name.
1st off thanx to everyone who took to time to look @ my situation.
To LaddyDady:
I did encode the DivX audio using Virtual Dub... and used that as my audio when converting (or attempting) my DivX to *.mpg to so i can then burn them with a authoring program.It seems as if MystaMax didn't encode the audio at all. From what he says in his post he started with a wav file and ended up with a wav file
To DoggieDaddy:I noticed when choosing an output file name under the field box, it says "Output video and audio as individual elementary streams". i'm assuming thats what you're talking about. but that box is greyed out. its unable to be selected. Then i noticed on the 1st page of the wizard (step 1) that the choices for audio are different in the guide from the one on my TMPGEnc. My choices were }CBR Linear Audio{ }CBR MPEG-1 Layer II Audio (MP2) }VBR Linear PCM Audio{ & }VBR MPEG-1 Layer II Audio (MP2){. i chose another one (CBR MPEG-1 Layer II Audio (Mp2) and when I got to step five of the wizard it allowed me to uncheck, "Output video and audio as individual elementary streams". and now i can save it as one file, the *.mpg file that i needed!! So this whole problem was caused b/c of a little audio selection on the 1st page of the wizard of TMPGEnc. i didn't even noticed that the one in the wizard was outdated. i'll be more careful next time. THANKS FOR YA HELP EVERYONE!I don't do DivX but if you used the wizard in TMPGEncPlus and ended up with a .m2v and .wav file in step 5 of 5 you had to have the separate output file checked.
Whats a Simple setup for Video + Audio Syncing with Zoom H2n ?
By AjnabiZ in forum EditingReplies: 98Last Post: 19th Oct 2011, 10:41 -
Trying to create DVD from m2v and wav files
By JSLayton in forum Authoring (DVD)Replies: 8Last Post: 28th Jun 2011, 18:56 -
Combining VOB & AC3 to DV AVI Files for Editing in Premiere Pro CS4
By foochuck in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 15:08 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 06:44
