I was trying to back up a dvd with Osex, and the dvd was less than 4.4 Gb, so I decided to select the Folders option rather than elementary streams. When I tried to watch it, there were green lines through the video. So gave it another shot and tried to make an image with Osex, and that did not work either. Is there a way to get around that, or do I have to do elem. streams? Thanks.
I think that I know what the problem is: there is some kind of protection for it not to be played on a computer. I just tried playing the movie, and there are green lines across the picture... and it works fine on my dvd player. Has anyone seen this, and is there a way to get around it??? Thanks.
Actually, I was very wrong. For some reason, none of my dvds are playing with the Apple Dvd Player. They all play, but it seems like they are not decoding the copy protection.... there are green lines across all of the pictures. Very weird...
Try using a different decrypter, especially since the disc is less than 4.4gb. Using DVDBackup is the equivalent, more accurate version of "folders" in 0Sex.
It happens to me sometimes. DVD player won't play any DVD without green blocks. Usually a reboot and it's ok. An ATI Radeon 7000 PCI issue ?
Don't think it's a backup or protection issue at all.
Blu-Ray Rip Audio Sync Problem
By kerb in forum Blu-ray RippingReplies: 0Last Post: 7th Jan 2012, 10:44 -
resolution (?) image squashing problem with DVD rip
By suburban100 in forum Authoring (DVD)Replies: 9Last Post: 13th Sep 2011, 19:24 -
forced subtitle problem in avi.net with dvd rip of main movie only
By nathanm in forum SubtitleReplies: 0Last Post: 30th Apr 2010, 09:37 -
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 10:10 -
Frame Rate Rip Problem
By privateapples in forum Blu-ray RippingReplies: 0Last Post: 11th Oct 2008, 20:26
