Hello, I just received a bunch of home made anime VCDs (Japanese Dragonball Z episodes) that were captured of a VCR. The problem I have is that there is a very annoing sound delay of like 0.5 seconds. While this may not bother some it sure as heck bothers me. Very annoing during fight scenes, and in DBZ there's A LOT OF FIGHTING. My question is can I go back and fix the sound delay? What do I need to do this. Thanx for any help!
Download VCDGear from the "Tools" section.
Convert the *.dat on the VCD back to mpeg.
There are guides on this site on how to extract and re-join
audio.
(haven't had to do it myself yet so I can't really tell you how to myself)
i'm the same way about audio/video out of synch - any detectable lag/lead bothers the livin' heck out of me!!
what i've done to correct it is
1 - demultiplex the audio/video
2 - load video in vdub
3 - load audio in sonic foundry sound editor
4 - pick an obvious point/frame in the video where i know that a particular sound is about to begin (gun shot, door slam, etc) and note the time
5 - find that precise point in the audio, note the time
6 - take the difference in the two times and adjust the audio accordingly
7 - re-encode the adjusted audio back to mp2
8 - remultiplex audio/video
9 - reburn to VCD
i've done this on MANY VCDs, in particular those that i created when i started this hobby, and the difference is so noticeable, you'd swear even the video looks better.
<font size=-1>[ This Message was edited by: hitechjunkie on 2001-09-14 15:48:56 ]</font>
DVD Video made with PiTiVi and DeVeDe -- no sound. How do I proceed?
By VanillaMozilla in forum EditingReplies: 8Last Post: 7th Mar 2011, 11:02 -
Try to edit my mpeg but no sound!
By leegundo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 2nd Aug 2010, 10:56 -
how to suppress vocal on karaoke vcd made from video files dowloaded
By sabaideevh in forum Video ConversionReplies: 6Last Post: 3rd Aug 2009, 05:57 -
Problem with Magix Movie Edit 14 - Sound muted between objects.
By Jo The Veteran in forum EditingReplies: 1Last Post: 3rd Jun 2009, 17:49 -
No sound on dvd burned with convertx2dvd made from ratdvd
By maureensullivan in forum Newbie / General discussionsReplies: 10Last Post: 5th Aug 2007, 18:41
