  1. I type in 490Mb for the size that it should transcode the vob file but the process went up to 117% and the transcoded file is 580Mb.
    Do you know how to get it fix?
    WLJ!o!!
  2. What was the original size?
    Don't give in to DVD2ONE, that leads to the dark side.
  3. Member wulf109's Avatar
    Jul 2002
    I've run into this problem when the input files are not in 1GB chunks,which is the normal size for a vob file. Are your input in 1GB sizes?
