In the past, I chose 'MPEG Layer-3' for my audio compression but for some reason, that isn't an option when I use it now. did I delete or add the wrong codec or something. I know I've been adding/deleting a bunch of stuff that \I've been experimenting with. Anybody got any ideas why 'MPEG Layer-3' is no longer an option for audio compression on Virtualdub for me? Any help is greatly appreciated!
Vdub used to decompress the audio from an avi file. It doesn't seem to do it for me anymore
Says no decompressor can be found to decompress the audio format. But it's div4 and I have that divx codec downloaded. It was able to decompres before!!!
Divx is a video codec, you need an audio codec!Originally Posted by MusicLover
Test your file with Gspot, it's in the Tools section. It'll tell you what you need.
8)
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
MPEG2 Compression - Question
By b1tbull in forum Video ConversionReplies: 3Last Post: 2nd Jul 2010, 03:14 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 19:00 -
HD Conversion and Compression Question
By GFK2009 in forum Video ConversionReplies: 5Last Post: 30th Apr 2009, 17:03 -
Vegas Audio compression question
By outerspacerace in forum EditingReplies: 1Last Post: 2nd Jun 2008, 02:51
