Hey,all
OK, I'm new in this area and I know only a little so plz answer me in simple words.
I have an SVCD moive that I downloaded with subs in *.sub format. The movie was probably ripped I think but not by me so now I want to add the subs and I don't care if they are siwtchable subs or not I just want to add them for good so I can burn them and see them on my DVD player that I already watched in it SVCD movies without subs so I guess that the movie should work also with subs.
I tried many guides but they are all for divx and I want for SVCD, plz tell me that it's possible and or send me to a guide or if you are very nice write it for me.
Thanks alot
Well, i prefer the permanent subtitles, because the no permanet subtitles depent of you home dvd player.
If you choose permanets ones. depend of mpeg2 (svcd) encode you use. I think the best is canopus procoder.
With procoder:
You need one little palication named ffdshow. Install it
then go to configuration --> mark the subtitle box ---> and in the submenu fonts, put the configuration you want, subtitle font, scale...
then, put in the same directory the video file and the subtile file (sub file) and rename both with the same name, example: popo.avi popo.sub
Open procoder and open the avi file normally and make the things you make normally, automatically, the subtitle will be in your svcd.
With Tmpgenc:
You need an aplication named virtualdub and a filter named subtitle.
open virtualdub, open your avi file, go to video --> filter --> add
Then click on subtitle, a window is showed and put there your subtitle (ssa file) --> ok
Go to file menu --> frameserver --> ok and put a name for your vdr file --> start frameserver.
Open Tmpgenc, and instead open your video file, open the vdr file, and make a svcd.
I think, i am not sure, the first method works with cce encode too. -
The first method works with tmpgenc also. You don't have to frameserve.
Thanks,
Tell me if I'm right you want me to save as the movie after it's played by the ffdshow it's I think a very good way but the sub are in hebrew and the program dosn't support the lang.
So if anyone has another idea plz.
plz help me
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 08:55 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 17:36 -
mkv (x624 + 5.1 dts + ssa subs) to mp4 (x624 + 2ch aac + burned in subs)
By chameleon789 in forum Video ConversionReplies: 2Last Post: 22nd Jan 2008, 04:01 -
What Tool: Type in subs while viewing subs from hardcoded video
By kpic in forum SubtitleReplies: 3Last Post: 6th Jun 2007, 20:29
