  1. Hey, for some reason some divx(avi) eps seem not to be working, for example I got this anime ep that was 180mb and it should be workin fine as I know others that have got if from the same place, but for some reason only half the ep works for me, I have had this prob with a few other divx files I have downloaded. When I open them in virtualdub it only shows half the file also, what can I do?
  2. Come on, some1 must know!
  3. I have had this problem before, downloaded a file first half cool second half non existent. The only way I have found round it is to re-download the file.
    On numerous occasions I have downloaded precisely the same file and it then works fine.....wierd.....I have no explanation.......anyone ?
  4. I tryed redownloading it a few times but still the same result.
