I am looking for opinions on the best quality mode with TMPGEnc while trying to fit most avi movies on 2-3 CDs.
Standard SVCD vs XVCD vs XSVCD
What bit rate settings do you use?
Well, first i think the best ( compatibility and quality) is SVCD, i use that.
I use CBR and the bitrate depend of how many disk you want. More bitrate, more quality. -
Calx:
Of the three formats you listed, for greatest compatibility use SVCD.
Now you said AVI movies in TMPGenc. For the settings I use it depends on where you got the AVIs.
If you are "ripping" to AVI then I suggest you get DVD2SVCD with TMPGenc, set it up for 2 CDs, 2-Pass VBR and High Quality Motion Search Precision. DVD2SVCD will select good bitrates for the SVCDs automatically.
If the AVI's are captures, I would use High Quality Motion Search Precision and 2-Pass VBR with a min video bitrate of 1000, max of 2520 and an average of whatever a bitrate calculator tells you. Another way to find the correct average bitrate , is to separate your avis into 2 or 3 files (for 2 or 3 CDs) and use TMPGenc's project wizard to tell you what value is needed to fill the CD.
2-Pass VBR does take longer to encode than CBR or CQ modes, because it runs through the video twice. It provides for better distribution of the bitrate; higher bitrate, where it is needed in fast-action scenes and lower bitrate in scenes with little movement that don't need as high a bitrate to maintain quality. -
The absolute best quality:Originally Posted by calx
SVCD on 3 disks, 2-pass (or more) VBR, average bitrate that will fill 3 disks (around 2500 for an average movie), minimum 1000, maximum 4000, highest quality motion search (very slow).
Unfortunately a lot of players (like mine) won't play SVCD's with bitrates that high.
Compromise setting (what I use):
SVCD on 2 disks (3 if over 100 minutes), 2-pass VBR, average 1800 to fill 2 disks (or whatever it takes if using 3) min 500, max. 2500, high quality motion search (slow).
My player doesn't like bitrates too high or low so that's what I use. I find quality starts to suffer if the average starts to go below 1800.
8)
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 22:10 -
Ripping DVDs as MPEGs using TMPGenc --- loss in quality?
By DieselsDen in forum DVD RippingReplies: 5Last Post: 21st Sep 2010, 13:09 -
TMPGEnc advanced settings for best quality results
By tdavid232 in forum Video ConversionReplies: 1Last Post: 15th May 2008, 19:02 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 13:15 -
What are the current encoders comparable to tmpgenc in quality?
By inuyasha in forum Video ConversionReplies: 24Last Post: 26th Jun 2007, 06:43
