Any Vcd that I burn on my Sony burner will no longer play right in my DVD player. The picture will have flashes of color spots, bars will show up containing portions of other pictures,its stops, part of the screen will go left and the other part will go right causing people to be seperated from thier legs, and the sound has loud pops and static in it. I know it is the burner cause I can take it out and burn the same files on another burner with no problems.
I have been burning Vcds everyday for a month without problems before.The burner is only 4 months old. The strange thing is that the burner can still burn data and music cds. How is this possible???
At what speed do you burn your VCDs? VCDs don't contain much error correcting information so if you burn them at high speed and some bits get flipped the picture may become distorted since the player can't figure out how to correct it. It may also be a case of media. Some media allow writing at higher speeds than others.
Try burning your VCDs at 2X or 4X and see if this works better.
_________________
Regards,
Willem
<font size=-1>[ This Message was edited by: willem on 2001-09-17 03:34:02 ]</font>
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 13:08 -
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 05:53 -
Burner won't burn DVDs
By Nephilim in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jan 2008, 16:23 -
DVD burner doesn't write anymore
By mr-scarface in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Aug 2007, 22:18 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 20:41
