I downloaded some moviez in DivX with AC3 Audio streams.
How can I burn thess to (S)VCD so I can watch it on my DVD player (Yamakawa 713) and still enjoy the incredible AC3 Dolby Digital Surround via my AC3/DTS amplifier (Sony STR-DB930QS)...
Seems that TMPG isn't recognizing the audiostream, what can I do???
thanx,
La Torcia
You can't have an AC3/DTS stream on a (S)VCD, you can however have a 5.1 channel Mpeg-2 audio stream on an SVCD. But good luck finding hardware that will play it correctly...
and what SW do you suggest? I wanna give it a try anyway, but I've got no SW (or don't know how to use it
) that supports 5.1. And how can I convert AC3 sound to 5.1???
thanx,
La Torcia -
I think you'll find what you are looking for here:
http://www.labdv.com/en/examples/svcd_audio.htm
actually, the easiest way is to just use the built in AC3 -> mpeg2 5.1 in rempeg2 from www.labdv.com/en/software/softlist.htm
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 01:10 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
