  1. for all you future AMD buyers...
    Make sure you buy a motherboard that supports the new AMD "PAL#####" something... because the newer chips that comes out will only support motherboard with AMD760 and above....
    I just bought a new system... AMD 1.4, ASUS A7M,256DDR, 40gigs, case,16xdvd,24XCDR, Geforce2Pro 64DDR, without keyboard, mouse, and monitor =( ... but pay under $1000
  2. Where did you read that ? can you give a link ? cause I know that AMD's future Morgan and Palomino will work on current SocketA mainboards, and you will only need a BIOS update so it will support the SSE extention of the AMD CPU's, and i've also read that you can use the MP version (Multi Processor) on regular boards.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. That's right, BIOS update only.
    However, make sure you get your mobo from a respectable company that will release updates!
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Feb 2001
    Rhode Island, USA
    I hope EpoX releases this update for their 8KTA3+ as soon as they release those processors.
    irc.webmaster.com port 6667 #DDR
  5. Thank you for the important information, aznguy!!!
    Tom Green Sucks!
  6. I read it from a mag. called Max#$#@ something... sorry.. can't help with the link... but I know its in this month mag. if you goto your local borders or BN bookstore...
