  1. When ripping DVD's to my Harddrive, it rips successfully but with very slow read speeds:
    DVD Decrypter results:
    Average Read speed: 1,436 kB/s (1.1x)
    Max Read speed: 3,506 kB/s (2.6x)
    When I write to DVD-R though I almost get the advertised writing speed of 2X:
    Average Read speed: 2,604 kB/s (1.9x)
    Max Read speed: 2,816 KB/s (2.1x)
    I am using a Toshiba SD-R5002 drive, Windows 2000 OS, Pentium III 600MHz, 644Mb RAM.
    It takes double the time to read vs. write.
    In the manual it says this drive can read at 2-4.8X.
    Is there something I have to configure?
    Firmware update?
    Is the drive defective?
    Please help!
    Thank you,
    David
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    many dvd drives will rip at 2x if ripping a DVD - it's a built-in governor on the drive.
    I have a Raite 8x drive, and with DVD Decrypter in .iso mode, it usually reaches between 5-7x. If I rip in file mode, it stays locked at 2x.
    My Sony DRU-500AX won't rip faster than 2x either in .iso or file mode, so I'm thinking about picking up a Lite-On 16x, I've seen a lot of happy forum posts saying that they will rip faster (anywhere from 8-12x).
    - housepig
  3. Agreed - I've just replaced my Matsushita SR-8586 with a Lite-on, mainly because the 8586 was really, REALLY picky when it came to reading DVD-R. I used to have to read most discs back in the writer, which kind of defeats the point, but there you go.
    I've just picked up a XJ-HD165H and have regularly seen speeds easily in excess of 2x. Between 6 and 8x on dual layers is not uncommon, higher on single layers. Some discs have exceeded that still, but then some discs are pressed better than others.
  4. Get a LiteON LTD 163 or 166 DVD drive for about $39 online. I have both and on single layer DVD's I have seen the rip go as fast as 15.5x and I average 6 to 8x for dual layer DVD's..
  5. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Region-freeing my drive produced a three-fold increase in ripping speeds, which was an big bonus as I only intended to region-free it.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
