Hello:
1. Does anyone know of a way to fix bad frames in virtualdub without deleting them????
2. What does frame masking mean?
3. Does anyone know of some other program besides virtualdub that does a good job of fixing bad/broken frames??
Thanks,
Comet![]()
1. You can try Divfix (Tools section). It's never worked for me though.
2. Masking means that those frames (bad and undecodable) are marked for deletion when you save the Avi.
3. Using VirtualDub-MP3 is more of a manual method, you scan then delete the frames yourself. I think it works better and I've found that it deletes fewer frames. Here's the guide: https://www.videohelp.com/forum/viewtopic.php?t=142555
8)
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
