Help!!!!!!!!!
Whenever I go to encode an avi with TMPGENC using the svcd template a popup box comes up and tells me that I can only use this for an evaluation period of 30 days and then I have to buy it. Does anyone know where I can get a free permanent copy of this particular template?
Thanks,
Comet![]()
It is not the template...
Its the function of converting MPEG-2 that is evaluative... I need to buy the software to have full access of MPEG-2 use... or use tmpgenc plus.
try morpheus or emule, instead, if you have them...
Fredİ -
The MPEG-2 function expires in 30 days. The MPEG-1 function will continue to work.
And do not forget to fo to the Tools section at left and get MPEG-2 plug in for TMPGEnc. It is freeware.
Hello.
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 11:52 -
Adobe Encore - calendar template available?
By The Linguist in forum Authoring (DVD)Replies: 2Last Post: 2nd Jan 2008, 05:14 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 19:54
