hi.
im trying to convert divX (XViD) to SVCD. when i try extract the audio to wav using virtual dub i get the error, 'No audio decompressor could be found to decompress the source audio.'
I'm sure i've got all the correct codecs installed (divx 3+4+5 and the xvid one, along with the regular mp3 ones).
anyone think where its going wrong?
thanks.
Try using the Virtual Dub MPEG-2 mod. It can convert video that has AC3 audio, which sounds like you have.
Hello. -
hi
it says everything is fine, all codecs installed for both video and audio are installed and there should be no problems with decompression
i sorta hoped it would find something wrong heh. -
which conflicts with what virtual dub says. VD says there is nothing that will decompress the audio. -
Try using avi2wav in the tools section of this webpage. You simply load the avi file into it and start it up. It will extract the audio into a wav file. You can then save the video portion of your file without the audio part . Load the avi into virtual dub. Click on audio and choose no audio. Then click on video and choose direct stream copy. Next, click file and choose save as avi. Vdub will then save the video portion of your film exactly as it is without the audio. Use this and the wav file you created with avi2wav.
Let us know if it works.
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 20:53 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Error when trying to compress with Virtual Dub
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 7th Oct 2008, 13:39 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 11:56
