I've just tried encoding a DivX film using TMPGEnc Plus 2.58.
The original DivX had a VBR audio track, so I ripped that using VirtualDub to a CBR PCM Wavfile, then, using TMPGEnc, encoded an mpg file using the two separate files - ie video and audio.
All seemed to go well, but when I viewed it, it had inverted the screen!
Any ideas?
https://www.videohelp.com/forum/viewtopic.php?t=150504
please use the forum search function. -
Thanks Baldrick, but I'm not stupid - I did search and everything I found referred to the Nimo pack which I DON'T have installed, so the advice in those threads was null and void!
Strangely, it wasn't just turned through 180 degrees, it was mirrored as well - but only in WinAmp 3's viewer which had grabbed the mpg files as default. When I reverted to viewing through PowerDVD or WMP9, it was fine.
So, next time before berating people for not searching, perhaps you'll ask politely whether they actually used the search first!
Thumbnails (FRAPS) upside down
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 24th May 2011, 02:31 -
Video thumbnails are upside down
By thegeeman in forum Newbie / General discussionsReplies: 2Last Post: 30th Mar 2011, 05:36 -
Vegas 8.0 - ITS UPSIDE DOWN!
By 1320Video in forum EditingReplies: 7Last Post: 17th May 2008, 12:35 -
avi files upside down
By nocash in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 07:13 -
My video is upside down
By Baldrick in forum Newbie / General discussionsReplies: 42Last Post: 7th Oct 2007, 10:02
