Trying to create images of SVCD's with CDRWIN, I tried putting my SVCD in my burner first and then I put it in my DVD ROM, and both times I get this error
could someone explain me as to what this means, I have the ASPI Drivers installed...?ERROR: 'SET READ PARAMETERS' command line failed on device 0:1:0 Illegal command request (04h 00h 02h 05h IAh 00h)![]()
Check out my guide on converting .OGM format to an SVCD with Selectable Subtitles and Multiple Audio tracks.
https://www.videohelp.com/forum/userguides/170944.php -
ask at tech support for cdrwin .. they are very helpfull http://www.goldenhawk.com/
This is the reply I got from the Tech.
Our software doesnt officially support VCDs/SVCDs. If you are having a problem with them, there is nothing I can do to help.Check out my guide on converting .OGM format to an SVCD with Selectable Subtitles and Multiple Audio tracks.
VCDeasy makes Bin/Cue images of VCD's. 8)
Creating video from images WITH audio
By boyer in forum Video ConversionReplies: 13Last Post: 3rd Mar 2012, 02:01 -
Creating video with sound from multiple images
By caio1985 in forum ffmpegX general discussionReplies: 1Last Post: 5th Aug 2010, 16:23 -
Creating Animated Menu images
By DesertAvenger in forum Authoring (DVD)Replies: 4Last Post: 15th Sep 2009, 23:30 -
HD images
By toneystone in forum Newbie / General discussionsReplies: 3Last Post: 21st Oct 2008, 11:50 -
flash images -- Howto: copy-to-clipboard, and also creating them ?
By vhelp in forum Video Streaming DownloadingReplies: 12Last Post: 30th Mar 2008, 21:11
